It is currently Fri Feb 06, 2026 2:43 am
Post new topic Reply to topic  [ 378 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 19  Next
 Post subject: Re: 68 Mustang Fastback restorations, my sons 1st car.
PostPosted: Mon Jun 25, 2012 8:02 am
Coming together nicely!
Awesome job.
Jim :usaflag:
PostPosted: Sat Jun 30, 2012 7:36 am
The rear is out and we started prepping the bottom of the car for undercoating.
The springs are the only thing we will be reusing.
We should have the bottom finished this weekend!
Thanks!
Pat
PostPosted: Wed Jul 04, 2012 9:47 pm
The bottom is done! We used Dupli Color bed Armor and put 4 coats from the trans cross member aft.
Now on to the fun stuff, putting it back together!
Thanks!
Pat
PostPosted: Thu Jul 05, 2012 8:19 am
Nice detail. Putting it together-----> :yikes:
PostPosted: Sat Jul 07, 2012 10:28 pm
Kurt & I started installing the suspension today.
Kurt said this is the fun part and he is right!
Thanks!
Pat
PostPosted: Sun Jul 08, 2012 8:54 pm
We assembled the front brakes and installed the sway bar today.
May have it back on all four this week for the 1st time in over 1 ½ years?
Thanks!
Pat
PostPosted: Sat Jul 14, 2012 10:17 am
We test fitted one of the new wheels on the front to check clearance and the 16” wheel fit great and still have a vintage.
We also started installing the Dynamat on the fire wall.
We used Acetone to remove the Dynamat name as my A.T.D.D. (attention to details disorder) didn’t like the look of the logo.
We will mount the new AC air box next.
Thanks!
Pat
PostPosted: Sun Jul 15, 2012 11:51 am
The new air box is in and it installed with little modification to the fire wall.
All the coolant and Freon line go through the firewall where the original fan motor came through. The only hole we added was for the condensate drain.
The new AC system calls to block off both cowl hole under the dash but we plan on installing the original drivers side cowl vent so we took it apart and detailed it.
Thanks!
Pat
PostPosted: Mon Jul 16, 2012 8:02 am
:thumbsup1: Great Job on the car and Documenting.
I really look forward to your posts.
Good Job.
Jim
PostPosted: Mon Jul 16, 2012 7:12 pm
PostPosted: Mon Jul 16, 2012 7:13 pm
After hand polishing the quarter vents we installed the drivers side.
I think the grill that mounts just inside the quarter vent may have been painted the same color as the car but we went with black because we like the contrast.
Thanks!
Pat
PostPosted: Thu Jul 19, 2012 10:47 pm
We installed the tail lights and quarter extensions
The new repro tail light gasket did not work/fit well so we cleaned the originals and sprayed them with Plastic dip to build up the face that seals the water out.
It cool to see the tail lights in and looking forward to seeing the sequential lights work.
Thanks!
Pat
PostPosted: Fri Jul 20, 2012 10:27 pm
Man, it's a real bite when something that simple/cheap as a gasket is a piece of crap..... WTH...
PostPosted: Sun Jul 22, 2012 6:58 pm
This weekend we installed the rear, fuel line, and started mounting the rear valance.
We had to put the wheels on to check the fit, and to see how cool they look! We still need to repaint the grey center to a darker charcoal.
With a hole drilled through the new frame rail the new s/s fuel line fit in the original location
With the rear valance install we started fitting the bumper guards which need a lot of adjustment as they affect the fit of the bumper & valance.
Thanks!
Pat
PostPosted: Sun Aug 05, 2012 8:58 pm
Was away on a vacation last week, so not much work on Kurt’s car but today we did a few things. We put some Dynamat on the roof and fit a fuel tank & cover.
As soon as the Dynaliner comes in we will glue it over the Dynamat and install the headliner.
Had a friend make an aluminum fuel tank cover that we fit to the trunk. We will add sound insulation to the bottom but not install the tank for a few weeks as to leave room to work on other things.
Thanks!
Pat
PostPosted: Thu Aug 16, 2012 12:17 am
We have been working on a lot of things and most are not photogenic, like installing a new wiring harness. But we did install the headliner and have a few pictures.
We used some of our niece craft paints to color the ends of the headliner bows.
With the 3 bows in we installed the two aft rod retainers and note the overhead console mount with the light and some speaker wires stored inside.
With some glue, spring clamps, and using the old windlace to hold the headline tight. We started gluing the front then the back and then the sides with the corners last.
Thanks!
Pat
PostPosted: Sun Aug 19, 2012 8:47 pm
With the headliner installed the last thing to do before we can install the windshield is mount the new dash pad.
The new AC system requires a little large hole for the center vent so we cut that before mounting the dash pad.
We also installed the original defogger vents and a new center speaker
With the dash Vin-tag cleaned, detailed and reinstalled we used the old pad to locate the mounting hole. After a few test fits and massaging the metal frame w added 2 strips of 3/16 foam to the top edge to help firm up the fit.
We also test fit the new dash panels but left them off as we finish the work under the dash.
Thanks
Pat
PostPosted: Wed Aug 22, 2012 10:31 pm
One step closer to putting the motor in, as we finished make & fitting the brake lines, line lock, and proportioning valve.
Motor and trans are next
Thanks!
Pat
PostPosted: Sat Aug 25, 2012 11:44 pm
We bled the brakes and put the car back on all 4 for the 1st time in over 1 ½ years.
All good restorations use a milk crate for a drives seat at some point in the build ; )
We hope to put the motor in next week???
Thanks!
Pat
PostPosted: Sun Aug 26, 2012 6:41 pm
Hi Pat,
I've been following this thread since it began and its been a truly inspirational process. Your son has learnd a lot of new skills and an appreciation for all of the hard work it takes to completely restore a classic car. :btu:
Your photo coverage of the build has been very well done too and has been a big help in showing just how much work is necessary to complete this project.
I do have a technical question about how you post your pictures onto this forum. As the club's Historian and event photographer I have always been limited to posting just 3 pictures at a time. How do you manage to post a large series of pictures on each posting?
Perhaps there is a simple way to do this but so far I have not been able to figure it out! :yikes:
