It is currently Tue Dec 16, 2025 4:40 pm
 Post subject: Suspension upgrade here we go.
PostPosted: Thu Aug 28, 2014 6:09 pm
Last of the parts just came in. List follows
Steeda Ultra-light springs
http://www.americanmuscle.com/steeda-20 ... rings.html
Tokico D-Spec struts and struts
http://www.americanmuscle.com/tokico-ds ... -0509.html
Ford Racing GT500 Style Strut Mount Upgrade
http://www.americanmuscle.com/frpp-gt50 ... -0512.html
Camber plates
http://www.stangnet.com/2007/05/12/s197 ... e-install/
Ford Racing Front Lower Control Arms
http://www.americanmuscle.com/ford-fron ... 511gt.html
The only question I have is should I bother with the caster/camber plates since I have the GT500 mounts? or should I use half of the GT500 and the camber plates?
Now the trick is do I have the tools to do all this? Going to try and do it on Sunday.
'07 Torch Red Convertible GT
 Post subject: Re: Suspension upgrade here we go.
PostPosted: Sun Aug 31, 2014 10:51 pm
Put the rear shocks and springs in today. Had a bit of a panic attack when I put it back on the ground and the left side was sticking out about an inch and didn't look lowered at all. The right side was lowered and tucked in a bit. I'm like "damn, should have bought an adjustable panhard bar".
Well I went for a drive and when I got home both sides were down and the wheels were back centered. Guess the panhard bar did it's job after I drove it around a bit.
I did figure out I need bump stops for the rear axle. The one on the drivers side is about to fall out. Those should be easy to add later.
PostPosted: Mon Sep 01, 2014 2:22 pm
Grab some pictures of the installation...
I'd like to see it come together.
I'd use the CC plates and return the GT500 mounts. But I am not bothered by a harsher ride.
PostPosted: Mon Sep 01, 2014 11:29 pm
Aren't the stock mounts going to be shot? I can't imagine after 112k miles they are anything but. If I use the caster mounts I still have to have a top mount. I'm wondering if the mounts can be taken apart and use the base of the GT500 ones.
PostPosted: Mon Sep 01, 2014 11:55 pm
My SN-95 does not use a top mount with CC plates. My Tokico Blues go directly into the CC Plate bushing. But I have never worked on a new style Mustang. Even with the strut mounted spring, I think the CC Plates come with the top rubber isolator that mounts to the CC plate.
