 Post subject: Fog light install
PostPosted: Fri Jul 04, 2008 10:40 pm
PostPosted: Sat Jul 05, 2008 12:49 am
PostPosted: Sat Jul 05, 2008 3:12 pm
this is an easy one.
The v6 cars get the same dash harness as the GTs, but not the same underhood harness (99-up). So yes, the switch connector is there, and is active. However, the wire to the lamps terminates in the left fender-well. You'll need to remove the left splash shield to access the large connector containing the wire.
Now, you need more than lamps and a switch. You also need a relay. The wire from the switch will not directly operate the lamps. FRP offers a kit to install foglamps in a v6 car, containing everything you need, including instructions.
PM me if you need more help, Double D.
PostPosted: Sun Jul 06, 2008 9:59 am
 Post subject: Fog lites
PostPosted: Sun Jul 06, 2008 11:04 pm
