It is currently Tue Dec 16, 2025 12:56 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Test Drive my tires…
PostPosted: Thu Aug 08, 2013 8:18 pm
PostPosted: Fri Aug 09, 2013 7:12 am
Bring it up and we can sping the tires on the balancer, run it on the lift to check driveline and axles yadda yadda yadda..... Remember this, It`s only a problem if there is no solution and since there is always a solution then theres never a problem. :thumbsup2:
Im going to have to remember that one. lol
PostPosted: Fri Aug 09, 2013 10:05 am
Keep us in the loop once you've mitigated out all these distractions and the root cause has been found. BTW bob that balance job has made a big difference as I ran my car up over 3 digits recently and it was relatively smooth.
PostPosted: Fri Aug 09, 2013 10:39 am
PostPosted: Fri Aug 09, 2013 2:50 pm
PostPosted: Fri Aug 09, 2013 3:28 pm
PostPosted: Tue Aug 13, 2013 11:53 am
Bob found that the transmission tailshaft bushing was worn. I had replaced that a year ago, but there is no doubt that it is bad again. I replaced the bushing and seal and will see if it any better the next time I am at the track. If it wears out quickly again I will look into why it is failing so quickly.
Thank Bob!
PostPosted: Tue Aug 13, 2013 6:58 pm
amazing how you found that once you gave it a looking over.
PostPosted: Tue Aug 13, 2013 9:47 pm
I think.....I know the drive shaft is out of balance since the weight has been ripped in half on the front of the shaft. That will cause the bushing to wear out. There.....I fixed it. :thumbsup2:
