It is currently Mon Dec 15, 2025 3:50 pm
 Post subject: Gray Ghost Mods
PostPosted: Tue Apr 02, 2013 7:59 am
Gray Ghost - How did the engine and track mods turn out? Have you had a chance to run it on a track yet?
Jim
 Post subject: Re: Gray Ghost Mods
PostPosted: Thu Apr 11, 2013 9:57 pm
PostPosted: Fri Apr 12, 2013 10:41 pm
Glad you are happy with the engine. Hope you make your goal for VIR.
I had new tires and front end alignment done a couple of weeks ago.
The front end man found there was 1.75 degrees of negative camber. According to them spec was up to 1 degree. In order to adjust it into spec they had to change a camber bolt. Does this sound right to you?
Thanks
