It is currently Mon Dec 15, 2025 3:49 pm
 Post subject: Road Race Suspension: Post your mods!
PostPosted: Fri Sep 07, 2012 5:34 pm
I think its a good time to get a thread going of everyones road race/auto x suspension setups. Post up your suspension!
This is my setup:
* Vogtland 1.2" Sport Springs
* Prothane Front Control Arm Polyurethane Bushings
* Steeda Sport Sway Bars with adjustable HD endlinks
* Koni Yellow Sport Adjustable Front /Rear Struts & Shocks
* Steeda X5 Ball Joint & Bumpsteer Kit
* CHE A-arm brace w/ torque limiters
* BMR Lower Control Arms with poly bushings
* Steeda Adjustable Upper Comp/Street Kit w/ HD Mount
* Fays2 F2S Watts Link
* Steeda Camber Shims for Negative Front Camber (-1.7)
* Torsen T2R with 3.55 gears
* GT500 18x9.5 wheels with Hoosier R6 275/35-18 tires
* APR GTC-200 Adjustable Carbon Fiber Rear Spoiler
* Cervini Type III Chin Spoiler
* Sub Frame Connectors - welded
Performance Brake Upgrades:
* Wilwood SL6 (Front) and SL4 (Rear) Calipers
* Wilwood Stainless Steel Braided Brake Lines
* Wilwood 2-piece Slotted Brake Rotors
* Carbotech XP12/10 performance brake pads
* Agent 47 Front Brake lower grill cooling ducts
Last edited by Gray Ghost GT on Mon Sep 10, 2012 2:06 pm, edited 5 times in total.
 Post subject: Re: Road Race Suspension: Post your mods!
PostPosted: Mon Sep 10, 2012 1:51 pm
Here is the set up under my Cobra. All of the components are from Kenny Brown except where noted:
Bilstein Shocks and Struts
H&R Progressive Rate Springs
Heavy Duty Strut Tower Brace
Rear Shock Tower Brace
Adjustable Front Sway Bar and End Links
Offset Rack Bushings
Caster Plus System
Super Double Cross Sub Frame Connectors
Jacking Rails
Extreme Matrix Brace System
Aluminum Differential Bushings
Rear Steer Kit
Adjustable Rear Sway Bar End Links
Brake Upgrades are as follows:
Stainless Steel Brake Corporation 3 Piston Calipers powder coated RED
Stainless Steel Brake Corporation Stainless Steel Braided Brake Lines Front and Rear
Stainless Steel Brake Corporation Slotted Rotors Front and Rear
Hawk Brake Pads
PostPosted: Fri Sep 14, 2012 9:53 pm
65 Mustang
Front:
Boxed stock style upper arms
Manually relocated ball joint
Lower 1 inch (aka Shelby Mod)
Boxed stock style moog lower arm
620 Springs
IAS shocks
Baer Bump Steer kit
1 1/8 sway
-2.5 camber
Rear:
EVM 3 link with adjustable ride height
EVM watts links
QA1 adjustable shocks
Brakes:
13x1.25 front disc
11.65 rear disc
245 40 17/255 40 17 tire combo recently replaced with a 235 40 17/245 40 17 tire combo
Have broken BEFORE every attempt at an open track event so all I ever seem to do it drive it to work and drag race it for grins.
Nick
PostPosted: Sun Sep 16, 2012 1:45 pm
MM K-Member
MM tubular Front LCAs
Bilstein Sport Shocks
MM Coilovers
MM Front sway bar relocate
MM Road race rear LCAs
MM HD Torque Arm
MM Panhard Bar
00R Brembo front brakes
SN95 Cobra rear brakes
Im sure im forgetting plenty... I've only ever autocrossed the car a handful of times and have yet to take it to any driving event with the current setup. Really looking forward to trying it out.
1993 Mustang GT
1990 Mustang GT 'Vert
