It is currently Thu Jan 22, 2026 2:07 am
 Post subject: wipers
PostPosted: Wed May 16, 2012 6:32 pm
wondering if anyone has encountered this problem and if so, the remedy. when I bought my 83, the clown had a switch under the dash that was tied into the white wire on the wiper motor. When I took the switch out, when I turned the wipers on, they would not turn off until I turned the ignition off. After replacing the wiper motor, I thought I had this solved. When I turn the ignition key to the on position, everything works as it should, but when i start the engine, same problem as before.
 Post subject: Re: wipers
PostPosted: Tue May 22, 2012 6:57 am
There`s a short to voltage somewhere.
