It is currently Sat Dec 27, 2025 5:14 am
 Post subject: 92 Blinking Airbag light
PostPosted: Sun Oct 21, 2007 1:56 pm
Does anyone know how to clear a blinking air bag light code 12? I have tried to short the underdash clear code connector but its not working/ Any ideas?
PostPosted: Sun Oct 21, 2007 3:55 pm
try disconnecting the battery for a few minutes. sometimes that will clear codes.
PostPosted: Sun Oct 21, 2007 5:49 pm
I've tried that too, with no luck. Thanks
PostPosted: Sun Oct 21, 2007 8:27 pm
I can check the alldata tomorrow and get back to you.
PostPosted: Mon Oct 22, 2007 12:45 am
air bag lamps only blink when there's a hard fault, ie, a problem happening. IIRC, code 12 is an open circuit in the clockspring circuit.
PostPosted: Mon Oct 22, 2007 9:38 am
PostPosted: Mon Oct 22, 2007 2:59 pm
 Post subject: re:
PostPosted: Mon Oct 22, 2007 4:21 pm
PostPosted: Fri Oct 26, 2007 9:48 pm
Did you find the problem yet? And did you get the fax?
PostPosted: Sat Oct 27, 2007 6:11 pm
PostPosted: Sat Oct 27, 2007 7:56 pm
PostPosted: Sat Oct 27, 2007 8:30 pm
PostPosted: Sun Oct 28, 2007 6:48 am
PostPosted: Mon Oct 29, 2007 1:25 pm
PostPosted: Fri Nov 02, 2007 8:53 pm
