It is currently Fri Jan 16, 2026 8:27 pm
 Post subject: *sigh* Transmission is broken....AGAIN
PostPosted: Sat Apr 25, 2015 9:43 pm
Need recommendation for a reliable performance trans shop in the SEPA, NEMD area. I have an AOD with 4r70w internals, one piece shaft, big pan, lentech VB for 1, 2, 3 shifting plus switch for OD and a 3k converter....but I keep eating this damn things.....I've literally been forced to rebuild it now every spring 3 years in a row...and it just blow up again this afternoon.
Nick
 Post subject: Re: *sigh* Transmission is broken....AGAIN
PostPosted: Thu Apr 30, 2015 12:41 pm
PostPosted: Sat May 02, 2015 4:50 pm
400 at the back tire.
No trans brake.
This time it broke because I didn't turn the OD off and went to the track...darn thing popped into OD in the middle of the race at WOT....burned up all the clutches leaving it a slipping boat anchor
Going to give Anthony a shot at it over in Conowingo.
Nick
PostPosted: Sat May 02, 2015 11:41 pm
Besides the normal ones like Lentech and PA,...
Revolution Automotive uses a guy at Bowie Transmission for performance AT. I can ask for the name if you are interested. Mike on CCM works with Rev Auto. He might also know the name. Good luck.
PostPosted: Thu May 07, 2015 3:04 pm
I had my AOD done by Chris Lindell at Kellin Performance Transmissions. Very reasonable prices.
He is near Christiana Mall. Take a look at his web site...
http://www.kellinperformancetrans.com/
