It is currently Sat Jan 17, 2026 3:00 am
 Post subject: MD tint law enitre summary
PostPosted: Sun Oct 15, 2006 6:02 pm
YR-95, TYPE-FILM, WINDSHIELD-5", Front SIDE-35, Back SIDE (car)-35, Back SIDE (MPV)-ANY, REAR (car)-35, REAR (MPV)-ANY, L&R. MIRROR REQ.-YES, CERT. REQ.-YES, STICKER LOC-SPEC / ALL
** Pick-Up Trucks are not considered MPV'S
Explanation of the State Law Summary Chart
KEY
Type= Film (LT % refers to the film itself)
Net (LT % refers to the combined LT of film & glass)
Vague (language is unclear, legislative intent is unclear, or interpretation is uncertain, any information following is subject to change or interpretation.)
Windshield = Presumably, NR tinting is permitted above the AS-1 line. If the law specifies only the AS-1 line, AS-1 appears. If AS-1 or specified inches appears, the AS-1 is assumed and only the number at inches down appears.
(Note: NR is used in lieu of "No, Any, or a specific percentage" when the law permits unspecified "nonobstructive" or Transparent" tinting materials. In these cases, the legality of tinting inevitably depends upon each officer's discretion.)
Front Sides = No film, or the actual percentage of LT Permitted. (Note: Because they may vary from state to state, manufacturer's tolerances (i.e. + / - 3% LT) are not listed on this chart, nor are they included in these LT numbers.)
MPV = Multi Purpose Vehicle. A vehicle used for passengers on a truck chassis.
Back Sides = No film, or the actual percentage of LT permitted.
Rear = No film, or the actual percentage of LT permitted.
Mirrors (Left & Right required outside) = Yes or No.
(Note: Usually, a Yes means that dual outside mirrors are required if the back window is to be tinted.)
Certification Required: Yes or No. This refers to a requirement for manufacturers to certify the films they plan to sell before shipping them into the state.)
No (no sticker is required)
Rec (sticker recommended)
Specific (the state requires unique language & design, which may entail precise wording and sizing)
(1) Driver (the sticker is required between the film and glass on the driver's side window)
(2) Door (the sticker is required on the inside of the driver's side doorjamb)
(3) All (the sticker should be put between the film and glass on each tinted window)
Recommended (due to "officer discretion," a sticker can help officers identify legal tint more easily)
Locations: Driver's window, All windows tinted with film; or Driver's left door jamb
Important:
This summary chart of state aftermarket tint law information is not a legal document. It is the result of independent research, using several sources, of public state documents. Window tinting laws vary from state to state and province to province. Before applying any window tinting materials, installers should thoroughly review the appropriate state regulations as well as local enforcement policies to insure compliance with all applicable standards.
PostPosted: Sun Oct 15, 2006 6:45 pm
 Post subject: Shorter summary of MD tint laws
PostPosted: Sun Oct 15, 2006 10:06 pm
 Post subject: Re: Shorter summary of MD tint laws
PostPosted: Mon Oct 16, 2006 6:35 am
 Post subject: Law
PostPosted: Mon Oct 16, 2006 6:41 pm
