It is currently Fri Jan 16, 2026 9:47 pm
 Post subject: Headlights? Someone explain the differences
PostPosted: Sat Mar 11, 2006 11:50 pm
PostPosted: Sun Mar 12, 2006 2:44 pm
PostPosted: Sun Mar 12, 2006 4:41 pm
*nod*
I had purchased a set of SilverStars for my HD truck and the difference was very visable. Easy swap out if you already have the light housing to put the bulbs into. I'm a full step away, having sealed beams for headlights. I'd have to get the H1(?) lights that come as a package with the houseing and the bulb, then swap out for SilverStars....
Haven't seen much on if the H1's or SilverStars require a relay harness in addition to the lights, or if they can be run straight off the same plug as the sealed beams.
PostPosted: Sun Apr 02, 2006 7:30 pm
 Post subject: headltes
PostPosted: Thu Apr 06, 2006 10:32 pm
