 Post subject: Lose that weight - Your ride not your belly
PostPosted: Sat Apr 18, 2009 10:06 am
Stock Parts
Stock Door assembly with trim and window / electric motors 81 lbs each door.
All parts out of trunk/ Sound detonating 42 lbs
Stock Shaker 1000 stereo system complete 85 lbs
Stock front strut assembly with stock brakes and calipers 67 lbs each
Stock A/C system, compressor, condenser, lines. 38 lbs.
Stock Wiper motor and wiper blades 9 lbs (NOT fluid or washer fluid tank)
Stock passenger seat (no air bag, no power) 48 lbs
Stock passenger side air bag: 7 lbs
Stock axle tube weights 9 lbs (pair)
Complete AC system 33 lbs (not under dash-only in engine compartment)
Stock hood 30 lbs
Stock trunk 23 lbs (without wing)
Stock back Seats top and bottom 21 lbs (not including hardware for belts)
Stock rear seat belts, brackets and bolts 9l lbs
Stock front seats with rails –Pass side 42, Driver side 50 = 92 lbs
Stock rims/tire (51 pounds each) 204 lbs
Stock rear lower control arms 12lbs
Stock windshield 28 lbs
Stock manifolds 20 lbs
Stock h-pipe 32 lbs
Stock sway bar 13 lbs
Stock sway bar brace 16 lbs
Stock wind sheild fluid tank (full) 8 lbs
Stock small plastic piece (stock belly pan that connects to rad support) 1 lb
Stock K-member, a-arm, motor mount assembly 68 lbs
Stock rear lower control arms 12 lbs pair
Stock front rotor 19 lbs each
Stock front caliper w/line 11 lbs each
Stock front windshield weighs 28 lbs
After Market
Parts you might be adding or replacing with, so you can do the math with the stock weigh figures and get your total weight savings.
Granetelli Sway bar Delete 3 lbs
Bogart 15x3.5 Bare rim with alum center cap 11 lbs each
Bogart 15x10 bare rim with alum center cap 13 lbs each
Kooks long tube headers 16 lbs (pair)
Kooks off road X-pipe 18 lbs
Racecraft K-member, a-arms and motor mounts 46 lbs
MMR Rear seat delete 9 lbs (yes you will be adding 9lbs after you minus your seats and brackets)
Corbeau FX1 Pro seats Suade 16 lbs each
Corbeau Seat brackets 9 lbs each
Upr full race lower control arms 4 lbs
Speedglass. a 1/4 front windshield and all the rest 3/16 all the windows together weigh 40lbs
I have a pdf with tons more but I have no idea how or even if I can post it here. Sorry
PostPosted: Sat Aug 29, 2009 9:03 am
I removed my spare tire and installed a little air compresser like what they do on the Shelbys to save weight. The back end raised up about 1/2".
 Post subject: Weight
PostPosted: Sat Aug 29, 2009 9:58 am
Yea Paul needs his back end raised up again. lol. he just had it lowered. hehe jk Paul . Sacrete.
