It is currently Sun Dec 14, 2025 12:47 am
 Post subject: Eliminating Water Spots Offense, Defense
PostPosted: Fri Jan 11, 2008 3:46 pm
Like most problems, the best defense is a good offense. In this case, keeping a good coat of wax on your paint and window glass (that's right, use a glass wax) is the first line of defense against acid rain or water-spot etching. The second line of defense is to act fast to remove any water spots that may get on your vehicle. Time is relative. If you have a dark-colored vehicle and it stays out in the bright sun, you have less time to deal with the problem than a white vehicle in overcast conditions. It all has to do with surface temperature—the hotter it is, the tougher the water spots are to remove.
Removing water spots is fairly easy if you catch them soon enough. Re-washing your vehicle won't do a thing. Instead, mix up a solution of 1/2 distilled water and 1/2 distilled white vinegar in a spray bottle and carry it in your vehicle along with a soft, clean cloth. When you notice water spots, move the vehicle into the shade, let the surface cool down, spray the paint with this water/vinegar solution and wipe it off with the soft, clean cloth. The spots should come right off. Your waxed surface may be dulled by this solution, so apply a coat of wax when you get the chance
If you don't like the smell of vinegar and don't mind spending more money, commercial water-spot removers are available at most boat shops. They work the same way: Just spray the surface down and wipe off with a clean cloth. (white vinegar just as effective and a lot less expensive.)
What if the water spots have gone too far and actually etched the clear coat of your paint or the window glass? More drastic measures are called for. For window glass, try a good dry scrubbing with 000-grade steel wool to remove the spots without damaging the glass. If that doesn't do the job, then the windows will have to be polished with a commercially available glass polish and a power buffer.
Because today's water-based paints are very delicate (especially the clear coat), you'll want to experiment with the least-aggressive polish available. Try hand-polishing with a cleaner-type liquid wax. If the spots persist, then have a professional buff the surface with a fine polishing compound and machine buffer. Follow with a good hand waxing. Today's clear coats are very soft and thin, so make sure that everyone who attacks water spots with a power buffer knows what they're doing. Ideally, you'll keep the water/vinegar "first aid kit" handy so that the water damage will never get to this point.
PostPosted: Fri Jan 11, 2008 5:33 pm
I have a product I have been using for about 6 years, it is a waterless car wash. Nice thing about this is it has wax in it, so when you wash, you wax also. makes water spot clean up easy( due to rain).
The product is Quicshine 99, I get 3 cases delivered at a time and use it on all my vehicles, even makes our 90 aerostar look good.
