 Post subject: Changing the Dome light-Overhead console
PostPosted: Wed Jan 10, 2007 8:37 pm
HOW TO REMOVE THE DOME LIGHT ASSEMBLY or "OVERHEAD CONSOLE". Just grab it by the edges (driver and passenger side) and pull down. Pull straight and even. The unit is held up by two (spring steel) clips. Be advised you will have to tug pretty hard. When I put it back up I put a small amount of grease on the clips to make it easier next time.
