 Post subject: HOW TO PROGRAM PATS 2 and 3 keys
PostPosted: Sat Oct 14, 2006 9:20 pm
Programming Procedure
1. Place first already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) for at least 1 second and then switch to OFF.
2. Within 5 seconds, insert the second already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) for at least 1 second and then switch to OFF.
3. Within 10 seconds of turning the ignition lock cylinder to OFF, insert the new key into the keyway. Turn the ignition from OFF to ON (RUN) for at least 1 second and then switch to OFF.
The theft indicator light should go on for three seconds, after which the key will start the vehicle. Repeat this process, from the beginning, for each new key to be programmed.
