It is currently Thu Feb 05, 2026 10:26 pm
 Post subject: 1970 ignition problem
PostPosted: Sun Nov 04, 2007 3:32 pm
I have a problem with my 1970 cutting out. I discovered it's in the ignition switch or lock cylinder. If it turns to the off position just the slightest bit the car shuts off. I'm leaning toward the problem being in the lock cylinder. Can any one give a little help on how to change the cylinder?? Thanks...Chuck
PostPosted: Sun Nov 04, 2007 5:56 pm
Is the '70 a column key, or a dashboard key? If it is a dashboard key system, I probably have the directions in a shop manual (insterting a pin into the hole above the key and using a tool to un-screw the ring).
PostPosted: Sun Nov 04, 2007 6:01 pm
First year for the column. Thanks though
