It is currently Tue Dec 16, 2025 10:17 am
 Post subject: Installing new plenum/ throttle body
PostPosted: Mon Apr 02, 2007 11:07 pm
I just received a new Accufab throttle body/ plenum.... does anyone have or know where i can get instructions on the installation on a 99-04 GT???
They did NOT send me any.
PostPosted: Tue Apr 03, 2007 7:09 am
It's basically an "Unbolt the old equipment and install new equipment" project, just be careful when reinstalling the Throttle Position Sensor (TPS) so as not to position the tab on the sensor in the wrong spot, this can cause it to break.
PostPosted: Tue Apr 03, 2007 11:29 pm
PostPosted: Tue Apr 03, 2007 11:32 pm
PostPosted: Wed Apr 04, 2007 7:16 am
PostPosted: Wed Apr 04, 2007 10:10 am
PostPosted: Wed Apr 04, 2007 11:08 am
PostPosted: Wed Apr 04, 2007 11:26 am
PostPosted: Thu May 03, 2007 12:17 pm
I installed the accufab 75mm throttle body and plenum in my 03 gt convert last year, i did use my electrical meters to make sure I had the tps turned just right. It took my car about 2 weeks for the computer to relearn the correct idle, that is normal. Dont you love the high pitched sound of the air being sucked in?!
PostPosted: Thu May 03, 2007 7:37 pm
Oh yea! Ill go past someone that has their window rolled down and ill tap the gas as i go by so they can hear the whoosh and exhaust always catches their attention :burnout:
