It is currently Tue Dec 16, 2025 10:17 am
 Post subject: Removal & Installation of a Cobra Front Bumper Cover
PostPosted: Sat Jun 24, 2006 5:37 pm
I just finished installing a 99-01 Cobra Style bumper on my 2000GT. I thought I'd post some pics and give some instructions for anyone else considering changing the front bumper cover. So here goes...
Removing the old bumper:
1. Remove the screw clips from behind the grill above the radiator cover.
2. Remove the clips from below the grill on the bottom of the car.
3. Remove one screw from the driver side front fenderwell and one screw from the passenger side front fenderwell.
4. Reach behind the drivers side fenderwell and find the two nuts. With a 7/16" socket, unbolt the two nuts.
5. Repeat step-4 on the passengers side.
6. Theres a clip below each headlight. Push the bumper down around the headlights and pull the bumper away from the car.
7. Disconnect the foglight wire harness from the foglight assemblies.
8. The bumper cover is now completely loose from the car and can be removed.
 Post subject: Installation Process
PostPosted: Sat Jun 24, 2006 5:38 pm
Bumper Cover Installation:
Reverse the directions for the removal. Make sure to connect the side bumper bolts and nuts first prior to any of the other connections. To mount the fog lights, screw in three screws through the foglight assembly into the bumper cover. There's a screw and spring on the bottom of the foglight assembly that you can use to adjust the light projection.
Here's the finished product...
PostPosted: Sat Jun 24, 2006 7:11 pm
Looks nice :btu:
PostPosted: Sat Jun 24, 2006 7:34 pm
Looks great Corey! :btu:
PostPosted: Sat Jun 24, 2006 8:11 pm
Shweet!
I personallyl like the look of those fogs over the standard ones.
You get a good deal on the front nose?
PostPosted: Sat Jun 24, 2006 9:11 pm
 Post subject: Cobra Front end
PostPosted: Sun Jun 25, 2006 8:31 am
 Post subject: Re: Cobra Front end
PostPosted: Sun Jun 25, 2006 11:21 am
PostPosted: Sun Jun 25, 2006 12:38 pm
