It is currently Mon Dec 29, 2025 3:53 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Dec 26, 2007 8:55 pm
PostPosted: Wed Dec 26, 2007 10:14 pm
PostPosted: Wed Dec 26, 2007 10:32 pm
PostPosted: Thu Dec 27, 2007 2:02 pm
Might have one more project if we have time and someone's brave enough to try...I have a slow electrical drain that keeps killing my battery. God only knows whats draining it! Anyway, I'll probably just take it to a repair shop to let someone else worry about.
:banghead:
PostPosted: Thu Dec 27, 2007 3:50 pm
Corey, I'll gladly look at that for you!
FYI, I also have wiring diagrams and service manuals on DVDROM for 1992 to 2000 that I'll bring with me, along with a printer.
PostPosted: Thu Dec 27, 2007 4:09 pm
That would be great if you could bring both the gasket & filter. I'll pay you back that day. If you can't make it that day, just let me know & I'll swing by your shop sometime between now & then. Thanks Mark!
I'll get them in time for the 5th...no problem!
Wonder if we'd have time to get a couple other projects done, have some things on the '93 and as I mentioned on the '03 I'd like to take care. Hmmm..
Anyway to bypass a bad 02 wire code? When I replaced my throwout bearing, we mistakenly pinched the wiring between the trans and the motor (d'oh!) and now I get a "check engine". The mil eliminators take care of my off-road x-pipe situation and I've even tried replacing the 02 sensor that's showing the code, but the light is still on, so I figure it must be the wiring issue??? :confused2:
PostPosted: Thu Dec 27, 2007 5:40 pm
PostPosted: Thu Dec 27, 2007 5:52 pm
PostPosted: Fri Dec 28, 2007 8:25 am
Mark, I ran into a problem similar to yours. What I found was the wire was bad where it was pinched. I simply cut out the damaged section and spliced in another short piece. It was coming up as a heated o2 circuit fault code.
That's what I plan on doing, it's just not in an easy location to get at. Did you have to remove the tranny or anything again to get at the wire(s)?
PostPosted: Fri Dec 28, 2007 8:26 am
PostPosted: Fri Dec 28, 2007 9:29 am
PostPosted: Fri Dec 28, 2007 11:59 am
PostPosted: Fri Dec 28, 2007 10:36 pm
PostPosted: Sat Dec 29, 2007 8:24 pm
PostPosted: Sat Dec 29, 2007 8:47 pm
 Post subject: removing air bag cover
PostPosted: Sun Dec 30, 2007 9:47 am
PostPosted: Sun Dec 30, 2007 9:50 am
PostPosted: Sun Dec 30, 2007 1:27 pm
PostPosted: Sun Dec 30, 2007 1:29 pm
PostPosted: Sun Dec 30, 2007 2:48 pm
