It is currently Wed Dec 17, 2025 6:40 am
 Post subject: Need some help
PostPosted: Wed May 13, 2009 10:36 pm
I hope this is the right section but here goes i have a 2006 ford fusion
i am having a issue with the key off and in my hand the front turn signal stays lit in the bright pos like it was when it flashes and the front pass does not work at all but both rears work. I have replace the turn signal switch that did not fix it and replaced both bulbs still the same all the fuses are good even swapped the bulb sockets still the same i am at a loss on what to do next besides taking it to the dealer. It has no flasers like my stang it has to be something that controls these any help would be great thanks
PostPosted: Thu May 14, 2009 7:37 am
Sounds to me like their is a short in the wires heading to the front. You'd have to try and trace the wires but I'm sure like all modern cars it goes into some gargantuan wire harness that is impossible to trace.
PostPosted: Thu May 14, 2009 9:06 pm
they do have a flasher but it will look more like a relay than the old style flashers. I can pull and print the wiring diagram at work for you if interested. Let me know,
John
PostPosted: Thu May 14, 2009 10:15 pm
Do they call it the smart junc box ?
PostPosted: Fri May 15, 2009 12:50 am
my 08 did that, and the dealer said it was a recall, not sure what the problem was, bob davidson fixed mine took about 3 hours
